'02 CL600
After re-installing the shifter upon repairing the broken plastic lever that got her stuck in Park my Tiptronic will manually shift down but not up?
The transmission(D) shift just fine with kick-down, etc.
I have to put the shifter back into D and than she gets back into any gear she needs to be.
Is there a computer reset needed? Or is there an other reason why this is the case?
'02 CL600
Discussion Starter #2
After having the Indy look at the Tiptronic problem it turned out that by reinstalling the shifter I inadvertently reinstalled the shifter ever so slightly to the left. This caused the Tiptronic handle not hitting the right button for upshifts as easily as before. Simply hitting the stick a little harder makes the upshifts work perfectly fine. Another issue resolved?!
