Re: successful 30% looks dark on white
35% all around, but with a black car and charcoal interior, it looks darker in the daylight.<br> <br> Yes, i have vertical scratches from the windows rolling up and down. someone from mbworld.org said you need to replace the window mouldings on the inside with 'moleskin' <br> <br> Also, don't use a metallic-based tint on the rear window, otherwise you will get static on radio reception. Test the tint by placing a sheet on the rear window (even on the outside) and if you immediately hear static, then you know it's metallic.<br> <br> <br> <br>
