I have been having a tough time trying to find TDC to do the timing on my Mog(om352)
The timing adjustment is simple but finding the TDC is not.
My vibration dampner has only one mark so I,m not sure if that is FB or OT, I adjusted it of the line and something sounded way of on the valves.
I sighted down the timing gear case but could not see an arrow, I could see the marked teeth on the IP gears but the only thing resembling an arrow is a small stub off the back(inside) of the hour meter. So I adjusted off that, I have lots of low end power/ no rattle of valves but my exhaust temp zips up to the red way to fast for my taste (on the flats/6th gear/punch it and within a few seconds I'm at 1250).
I had the IP out when the cab was tilted before and I do remember that I lined it up with a very distinctive mark when removing and putting back! Only now I cannot see/find it.
My IP is not advanced at this time!
If anyone can give me some pointers It would make my week.
G Vavra
G Vavra
