I just bought a 78 450 SLC and found the timing at idle with vacuum attached to be 5 ATDC. I set it to 5 BTDC and it seems to run much, much better. Even at this setting, I seem to be getting only about 20 degs of total mechanical and vacuum advance. That's kind of lame, isnt it? No wonder I see people on this list advancing their timing to 10deg or more. This engine ought to be able to take at least 35deg full advance without pinging. Does anyone know what the specs are for the initial timing ( i think its spec'ed at 0 deg BTDC), the total mechanical advance and the total vacuum advance? Or maybe just what the timing should be with full advance?
I was also curious if anyone has upgraded their ignition to something more modern like a capacitive discharge, TFI coil and bigger distributor cap. That oilcan coil has just gotta go. I make better sparks just walking across a carpet in socks.
