Hi there
Attached a PDF (I hope, new printer) which should help you. Let me know if you need anymore help as have just removed one myself.
Tony
NETDVN,
I just removed the supercharger on my SLK230 using Toynee,s picture. Quick and Easy!
I assume that you have removed all the air hoses and air filter housing equipment from the passenger side of the engine
1. Remove coolant tank (2 bolts) and hoses from top driver side radiator. Move to side.
2. Remove wiring connector from driver side of fan shroud - just below where coolant tank was. Undo the two clips on top of the shroud/radiator and pull up on shroud to remove it and a cross hose at the bottom that has an open clip.
3. With a ratchet and socket 7 or 8 mm loosen the belt tensioner and remove the belt, being careful not to turn the crankshaft. You should have it marked at the correct BTC marks. I moved mine but just put it back on the marks after removing the belt.
4. Loosen clamp and pull inlet hose loose from the forward supercharger inlet.
5. Remove the four bolts from the top half of the inlet assembly and the small nut & bolt that connects it to the air tube assembly that is connected to the block. Loosen air tube nut at block so that it can be pulled out.
6. Remove air tube assembly and top part of supercharger taking care not to drop anything into the supercharger. I taped over the opening to be sure.
7. Completely loosen the four bolts depicted in Tony's pictures and the supercharger should be loose. I was only able to remove the top two and the rear bottom one by turning the supercharger and moving it forward and backward bit. The water pump housing interferes with it but I was finally able to position it forward enough to remove the chain tensioner. Bingo!
