stff or try reading your manual. Both are covered. mmkaythanksbye.when is it recommended to change the timing belt for a 2002 ml320 with 82,000. Or how can i find out if it was changed? also how long should you drive with those double wrenches blinking? any info is highly appreciated!
soyou never have to change the timing chain? What about the doubl blinking wrenches? how long can you drive with that going on?MLs have timing chain (not belt).
Please search the forum, this topic has been discussed before.
In short, no need to worry about timing chain replacement for ML.
