I got a free
'73 450SL from my Uncle last year. I drove it up from NC after changing the oil and putting new tires on it. It sat since 1995 prior to that, and made the 800 mile trip in the pouring rain with little trouble, averaging 14 or so MPG. The car has approximately 190K. It's in very good shape- physically. The interior is above average, and the exterior is outstanding. Completely rust free southern car. Both tops are perfect, and all the trim is perfect.
Now that the car is safely home, it needs a ton of work.
This is going to be a long post, because I have a lot of questions/concerns.
I pulled it out of the garage last weekend, after I added transmission fluid to it because it would not move. The transmission fluid was found on the floor. So that's probably a hose or a bad gasket, I'm not really worried about that.
Last year before I put it up, it developed a violent shake when accelerating. There's also an occasional loud clunk that I can't seem to nail down. I'm not sure whether or not this is flex disks, center bearing, both... or:
Is it engine related? The engine seems to run fairly well- but this problem seems to only occur at lower RPMs. If you're going say 40 mph and push the pedal down, it'll shake like crazy accelerating. If you put it in manual 2nd gear at the same and the engine revs up, the acceleration is smooth. So maybe it's a motor mount?
About the engine. I know in the 126 forum, a lot of the guys talk about timing chains. Does this engine need the timing chain and guides replaced at an interval? I can be pretty sure if it has ever been done, it was a long time ago.
I am sure it should have the spark plugs changed, I've read on here to only use the old style plugs. Can anyone suggest a brand and part number for the correct plugs? I do not want to cause any damage to the electronics.
The electrical system is a nightmare, but I'll deal with that on my own- I'm not scared of wiring, motor-vehicle wiring is my thing.
I'm a competent mechanic with plenty of good tools, I'm not afraid to buy more if I need them. I'm also not scared of any job. But I have limited knowledge about this particular car, and I know from my other MB's that making a mistake would be more costly than just doing it right the first time.
I'm most concerned about the chassis/driveline noises, then the engine mechanical stuff.
