OK, Chas -
Some more thoughts on this FTB cab tilting process .
A. How much heavier is the DOKA cab than a standard cab ? According to the UHN builder's guide, the DOKA cab adds an additional 270 Kg to the cab weight ( 595.2 Lbs). This is probably pretty close to what you and I have, as the cab structure has remained pretty consistent.
The UHN regular cab has been stretched a few inches over the SBU cab of your era, but the additional DOKA weight should be pretty close, I think. The later UHN's have a revised Rear Seat structure, but I don't think that is would have affected the weight appreciably. I'd just round it up to 600 Lbs.
B. If I had to tilt my cab up enough to get the engine out, I'd lighten the cab as much as possible. I'd take the rear seat cushions out completely (Very Easy to do) and empty out the storage compartment under the seat - take out the jack and anything else stashed under there, leaving the Webasto Aux heater. Once you get the rear seat out, that rear space really looks rather large ... and you may start pondering... I did anyway.
I have the seat-and-a-half on the passenger side, so I'd pull that out. I believe that you have the single passenger seat -
I might pull that at well, maybe both seats, since lighter is better.
C. The front Pivot pins - these things are being asked to support the extra weight of the DOKA cab, at an angle that the DOKA cab is not designed to reach, which is why I'd lighten the load as much as possible, within reason. The photos of the DOKA at an elevated level from Schüssler show the pins working, so if they are in good shape they would appear to be up to the task.
I'd grease them up so the pivoting process would be smooth and the clamps would not hang up or grind into the paint too much.
Assuming the engine has to come out, then I'd probably leave the cab up until the engine was returned to its spot, as I think that minimizing the up and down cycles would tend to reduce the chance of damage.
D. The Pins - I looked at them thinking that I might find a way to brace them to the floor. I was thinking that backing them up to the floor or the bumper would help eliminate the potential bending moment that would be induced by the cab during the pivot and at rest in the FTB position.
The problem is that there really isn't enough room to grab the pin on either side of the pivot clamps (hinges) - whatever was put in place might interfere with the smooth movement of the cab as it rotates, which could lead to some big problems.
Once the cab is all the way up, then I'd look to fit a leg from the Clamp / Pin combination to the floor to counteract some of the load on the pin. This would take the load straight to the floor, so you would not have to worry about the weight of the cab bending the pins if it had to sit for an extended period of time, while your engine block was out being chromed or something.
Because the hinge clamps are attached to the the bumper support, by fitting jack stands directly under the bottom of the clamps, you would take the load to the floor, rather than having the full weight of the cab pushing the pins down onto the front springs. The jack stands would take the suspension out of the mix, and 'push back' against the pins.
Another thing that might work is to use the extra eye on the pin assembly meant for the cab shock. You might be able to make a leg that bolts to this eye and extends to the floor. Again, I'll have to look at this in the flesh, but it might be a handy way to attach a leg. This could not be used until the cab was fully rotated, because the shock mount is slightly off axis in relation to the cab pins.
Jack stands are probably the simplest solution, and a few minutes looking at my truck should verify this. Easy and the quicker solution.
E. Elevating the cab - I think I'd prefer to hoist it from above using the two cab rings, rather than pushing it up from below. The factory hydraulic jack only goes so far, and will have to be disconnected for the cab to reach the full height, so disconnecting it at the upper mount on the cab and ignoring it might be the way to go.
I think that an ideal way to hoist the cab would be with a chain hoist mounted on a traveling dolly on a beam crane, in a shop with a ton of head room. The dolly would allow for the crane to be directly over the rings for the whole process, rather than being offline as the cab rotates.
In lieu of the dolly on a beam crane, rolling the UNIMOG on the shop floor, under a hoist in a fixed position should achieve the same effect. Looking at the body of the DOKA, you would not want to be in a position where you are pulling over the top rear corner of the cab - it is much better to lift directly up on the rings and roll the UNIMOG to the rear to keep the rings under the hoist throughout the lift.
Once the cab is in the FTB position, then maintaining a little tension on the rings will also take some load off of the pivot pins. Just a little, as you don't want to damage the rings.
F. Once the cab is up, I'd add two legs under the rear corners. I'd probably use 4x4's cut to length, with both legs attached to a single 2x6 or 2x8 flat against the floor (if possible), and then cross brace the legs to each other, and then finally ratchet strap them to the frame to keep them in place.
Based on the angle indicated in the Schüssler photos, it may be that the (angled) legs have to wind up on top of the frame rails, butted up to the rear box. It is one of those things that you have to figure out once the cab gets up there.
As a safety, I'd run ratchet straps from the two lifting eyes to fixtures on my rear box, so the cab could not over-rotate if something failed in the hoist.
You could use screw jacks (shoring props) or steel, but with a Skilsaw and some lumber I could bang it right out.
I'd chock the wheels every which way.
G. A team. The more the merrier, but I think two is the bare minimum. I got mine tilted by myself, but it would have been better with a second pair of eyes on station (and, I was not going all the way up). One guy on the hoist, one at each front corner would be good, and they could roll it as it was being elevated. That would be reasonable - three people. More if you have them.
