OK, this is an attempt to look at and illustrate the situation when confronted with tilting the DOKA cab in order to remove the engine.
The chore is basically the same as the procedure with a regular cab, it is just that the length and additional weight of the DOKA cab complicates things a little.
The crux of the issue is raising the cab enough to get the engine out, and also accounting for the engine hoist. The requirement is to get the cab out of the way enough so that there enough vertical space to get the engine up and over the frame rails, while keeping it clear of the shift plate structure.
If the Engine has the Claas overdrive on it, or the PTO drive housing, then things will be more complicated yet.
Once the cab is tilted enough to create this clearance, then whether it is a Regular Cab or a DOKA, it doesn't matter - the excess length of the DOKA is up and far out of the way. Now, getting it up all of the way is another issue, but more on that later.
How much tilt ? Well, there is only one answer : Full Tilt Boogie. The maximum tilt takes the front contour of the fender within an inch of the bumper. The raised cab is a little different , as the cab has been raised 100mm. so the pivots are that much higher to begin with, but when tilted to the maximum, the gap to the bumper is also pretty tight.
Some photos shoeing the Full Tilt Boogie.
