I just bought a C320 4Matic with 90,000 miles on it. I noticed a ticking noise at idle. It gets faster as you accelerate and stays regardless of engine temperature. It sounds very much like a sticky lifter but does not go away. It is very noticeable but I would not consider it a knock so much as a tick.
Shortly after leaving the dealership (3 hour drive at 70mph) I slowed to about 35 mph. Just as I slowed the check engine light came on. I did fill up with premium (91 octane) fuel and was very careful about tightening the fuel cap. I tried starting the engine 4 times in a row as stated in the manual but the light remains on. I'm wondering if this could be related to the ticking noise.
The other thing I noticed was a considerable amount of road noise. Seems like a whirring noise from wheel bearings but I've never owned an AWD vehicle before so I'm wondering if the drivetrain is just going to be that lound.
The code turned out to be a PO432 and a PO422 Main Catalyst Efficiency Below Threshold, Bank 1 and 2. How would I know if I need to replace the catalytic converter or just the O2 sensors and how do I know which O2 sensors to replace?
The ticking noise does seem to be getting louder as I drive it and seems to be coming from the driver side of the engine. So far the loudest point I've found is when I listen directly to the driver side exhaust manifold.
Thanks in advance!
Thanks in advance!
