Hello, forum!
While I was dealing with a transmission speed sensor problem, today I noticed something else.
I have never seen this line before; but when I start the car this morning and get out of my parking lot, I noticed this oil drop line.
this line is coming from the passenger side underbody.
I used a tissue to check the color and it was black, which is a high chance of engine oil or else.
I already noticed that when I start the car, engine oil leaks from the valve cover gasket and drops to the exhaust, causing smoke.
This is underbody, and I was unsure if that is dropping from the rear main or a very leaky valve cover gasket.
I think the undercover collects oil and drops when I start to move because the mechanics said they didn't see drops while working on my car.
But I am unsure about the exact oil leak locations because there's a long oil line from the front jack port.
I don't expect much to seals since this car is a 71000 mi California-kept 16-year-old car.
I'm doing a 3000mi oil change and I never had a low oil warning before.
Since the valve cover leaks pretty intensive- which makes smoke, so I'm thinking should I try replacing the VCG first and wipe it to see the exact location.
Currently, I'm short on money for RMS replacement since I had problems with the transmission.
do you think this is a pretty big issue and I need to replace the seal asap?
