1 - 17 of 17 Posts
2003 ML500 2002 S430
Guys its the lower of the two with the four bolt arrangment. It is wobbling (oscillating about its verticle/horizontal axis).
Is this the water pump pulley?
What do you suggest that i do? I have taken the day off from work to take care of this, I would appreciate any suggestions.
Thanks so much! Pete
Discussion Starter #2
Hey guys, Evidently it is the water pump pulley, I think. Can I change just the pulley or will I need a pump too?
Thanks again. Pete
'07 C280 4matic, '06 530i, '98 ML320
I suggest you remove the belt from the pullies and spin the water pump pulley. Then remove the water pump pulley (by removing those 4 small bolts) and then spin the shaft for the water pump. If you feel any looseness or wobble/squeak, buy a new waterpump.
Waterpump is not that difficult to change. RMeuropean and Autohaus carry water pumps for reasonable price.
Thanks so much, I also noticed the shaft is turning true. just the pulley is out of line.
I will check it today.
Thanks again, Pete
Thanks so much guys,
Does anyone know where I can find a DIY on the pump/pulley change?
Any good places to get a pump/pulley?
Thanks, Pete
Guys does the tensioner have a tamperproof torx??
I thought I read it was a socket? I'm trying to pull te belt now.
Ok I was able to remove the belt by just sliding it off the wp pulley. Looks like it's the pump thats bad the pulley looks fine to me can I reuse it?
Can someone point me to directions to installing a new pump? Does the fan/shroud have to come off? What type size bolts hold the pump on?
Thanks in advance, Pete
Thanks for for the diagram, Just one last question. Is my WP a 2 or 3 hose conx?
thanks, Pete
Discussion Starter #11
Sorry I lied about the last question thing.
I would just like to know is it necessary to remove the fan. Ive read about removing the pump both with and without removing it..
Discussion Starter #15
Guys would this happen to be thew one?
Dont know about a 76 dollar pump though..
[ame]http://www.amazon.com/Mercedes-Cooler-1122001401-1122000401-11220000110/dp/B003523V6U[/ame]
Get a Graf water pump for $150.. rebuilt or China knockoff not the best decision.
1 - 17 of 17 Posts
