Bieng relatively new to M.B. I don't know how seriously to take their "warnings" yet.
My owners manual says not to use electronic equipment with built-in antennas inside the vehicle.....
I always use a garmin GPS and Spot tracker when I travel......problems ??
Thanx for any
W210 Moderator
this is likely the generic caution against high powered transmitters such as ham
radios, business band transceivers, etc. i've seen similar cautions begin years
ago when car manufacturers began to populate vehicles with more electronics,
black boxes, sensors, etc. when you get into dbl digit transmitters (watt output)
it occasionally affects car functions.
Thanx Raymond
I did have some concern about the Spot tracker but if GPS doesn't cause a problem I should be good to go...........
