1998 SLK 230 Kompressor, 1993 500 SEC
I need a cam sensor, but really don't want to spend £140 on it having already spent a fair bit on the car, and planning to spent on a Bosch MAF since it's got a clone.
Cam sensors being rather less complex things, are the "OEM" ones (whether they're OEM or not) acceptable? Seems I can find 'no brand given' for around £40, Vemo (OEM) for around £80, then MB for £140. It looks like Vemo might be the Bosch, but that may also be misleading marketing.
Mine fails when the car's warmed up, and is the original, so it seems reasonable to replace it, but I don't see any point in buying something that won't work.
2001 SLK320
At the very least, if you are going aftermarket try to find a brand that is at least heard of. A good length in warranty also helps I think.
Moderator
1998 SLK 230
there are a fair few companies that produce parts for MB... in this application any is OK. the only place where it matters 100% is the MAF... i replaced mine ages ago but i got it from this site
Pelican Parts - Product Information: 004-153-00-28-M375
you can prob find it else where but this is the site where i get most of my MB stuff and good shipping to aus...
I've gone with what should be a Febi Bilstein unit - at £39, considerably cheaper. Hopefully it's what it should be, seals correctly, etc!
Moderator
1998 SLK 230
should be fine... only other bit of advice is to use a drop of thread locker on the bolts when you put them in as that area is prone to vibration so it wont work its way loose over time...
obviously use removable threadlocker such as loctite 243 :thumbsup:
Well, the listing said Febi, the box said Febi, I guess I got what it said...
And my old sensor? Made by Febi. Car goes like stink now!
