ML 270 CDI
Hi yall, a few weeks ago my third brake light quit workin so i replaced the bulb, nothin happened, so of course went and checked the fuses (both boxes, the one in the engine compartment and the one at the feet of the passenger side) all the fuses are in perfect condition. Has this happened to anyone else?? or am i gonna have to go to the STEALER? IDEAS? SUGESTIONS? THANX
I would check if 12v appears at the bulb when the brake pedal is pressed or between the bulb and earth.
It is possible that the wire has been pinched where it enters the door or that the earth connection is not made.
If you do not have a multimeter it is a good investment (max. 15 Euros), the dealer will charge lots more for investigating what might be a simple fault.
