1994 S500 Sedan
Hello everyone: I have a 1994 W140 S500, but my third brake light bulb keeps burning out. Someone on the W140 board recommended that I replace the whole third brake light housing / assembly and that, while I was at that, I should look into getting a late model W202 C-Class third brake light housing / assembly, as they are LED and less prone to failure; does anyone know where I can source same for a good price? The color of my interior is gray. I called and asked my dealer's parts department, but they want a tremendous amount of money: $240 + tax! Otherwise, I e-mailed "Peach Parts" and they stated that such an order would be a special request order and that pricing would be comperable to the dealer. Much thanks for any / all help, JD.
95 C220
im not sure... i have an erly pre-facelift w202 and i still use bulbs for my third brake light...
you might want to check your wiring first... that might be the cause of all those burnt brake light bulbs... just curious... how long does it take for a bulb to burn out?
C200 Elegance
I suggest frequently blowing globes are caused by:
1. "unbranded" cheap globes - try Hella or Osram.
2. Incorrect wattage - to high caused overheating
3. Voltage regulator causing high voltage > 14.5. This would also shorten the life of all globes.
4. Poor connection - clean contacts and ensure tight contact
My W202, now 10 years old, has never had the third brake light globe replaced.
Joe
95 C220
Thanks for your prompt reply. I'd say about 2 months...
that's a little too quick... ive had my car for 6 years and i have never replaced the third brake light switch...
try a different brand of bulbs... if it is still the same, i would inspect the wiring.. maybe its getting a bit more juice than it requires... or maybe yet there's a short somewhere...
good luck!
1998 C280 SPORT
try ebay for a full assembly.
W123 300CDT and W202 C280
Did you touch the bulb with your hands? That bulb in the third light is halogen, DO NOT touch it with your bare hands when installing, use gloves or hold it with a clean cloth. Any oils from your hand will cause it to blow prematurely. I'm on my second bulb, the first lasted about 5 years.
