61 - 80 of 100 Posts
2005 CLK500 coupe
LED failure
I have the same problem as mekump: intermittent warnings that yesterday became permanent, the 3d rear light not lighting anymore.
You say that it cannot be a led failure because of their long life design. So what can i do before buying a new one? What can be wrong? Maybe a fuse?.
If a fuse is blown, there are likely other failures. Unless you have a wiring or connector issue, the MB system that monitors this is likely correct about the light.
While an individual LED is extremely reliable and long lived, it's not impossible for the LED ARRAY to fail. Mine failed because the broken plastic interrupted the continuity of the internal wiring. Examine the array to see if there are any breaks or cracks. If it looks bad, it is not likely you can repair it. Your only remedy is to replace it.
When I talked to my dealer, he acted as though he had never heard of a failure of this light. MB has no info on their internal dealer system that even acknowledges these failures, notwithstanding the extensive documentation on the internet. My MB parts guy certainly knew about it. Unless you're still under warranty, you'll have to eat the cost of a new light. As you can see from this thread, you can replace it yourself and save some money.
CLK 280 (231 bhp) Elegance, W209 Auto
I am just about at attempt replacement of the third brake light. I was quoted the ridiculous amount of £185.00 ($295) for replacement.
I have bought a genuine Mercedes part (A 209 820 1056) on ebay for £80 including postage. When it stops raining, I shall do the job.
keyhole's guide makes the job look really straightforward. I hope my job goes as simply as the guide suggests.
I am tired of Mercedes-Benz dealers producing telephone number prices for routine repairs. I was recently quoted a huge amount (£500+) to rectify a small internal engine oil leak. I finally had this fixed by a local garage who specialize in Mercedes for less that half the price the official dealer quoted AND, the did both sides of the engine whereas the dealer's offer was for just one side. My car has done only 34K miles and I feel that a modern engone should not be developing oil leaks at this mileage.
2007 CLK-350
I am tired of Mercedes-Benz dealers producing telephone number prices for routine repairs. .
Yes, me too. MB has an overtly predatory attitude toward owners. At this price level I have low tolerance for the defects and shortcomings of the car, including this tail light that disintegrates upon a hard slamming of the trunk lid. This will be a one and only ownership experience for me.
I think that I will buy another one but I agree with you about an "overtly predatory attitude toward owners" as I too have experienced this.
My particular car, the CLK, has now cost me so much money that the pleasure of ownership has been surpassed by the cost of ownership. I feel ripped off.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Remember, car dealerships exist to make a profit, and an authorized service center makes much more profit than the new car sales side. In fact, if it was possible to open only an authorized service center without having to sell new cars, they would be all over the place. The reality is, the manufacturers require authorized dealers to provide both service and new vehicle sales.
Dealers charge "market price" for their services. It's simple micro-economics of supply and demand. Since on average, MBZ owners tends to be wealthier and have less time to deal with auto repairs, they are more willing to pay higher prices to maintain their vehicles. My advice for anyone is to either learn to DIY, find a reputable indy mechanic, or maybe MBZ isn't the right brand for you.
2004 CLK 240 Coupe
Discussion Starter · #68 ·
You must have been very unfortunate and bought an abused car.
My experience has been quite the opposite and apart from this 3rd brake light, nothing (other than from normal consumables) has needed replacement since my ownership started in 2006. The build quality of my CLK is amazing - and no rust either!
Just noticed this happen to our 2004 clk320. The lens finally broke off clean where it was slotted into the trunk opening. Looks like the replacement should take no more than 30 minutes to an hour.
Has anyone tried to put some kind of thin cushioning along the edges of the new plastic lens to maybe help absorb some of the impact? Might not prevent it from ever happening, but would certainly prolong the life before the next replacement. I think a thin film of tape around it would do. I think the opening in the trunk can still accomodate that.
Also noticed that the light itself doesn't light up anymore.
2004 CLK 240 Coupe
Discussion Starter · #71 ·
If you check post #3 you will see that the new light assembly comes with an adhesive foam strip surround that is a shock absorber. Diksum suggested also using glue, but I'm not convinced that it is necessary.
Once the plastic cracks, the circuit can soon get damaged. Does it throw up a warning on the cluster at switch-on?
Current CLK 320 Cabriolet Former 1986 E 300D and 1959 190SL
Third Stop Light test
Excellent post for replacement of this light. I assume the steps are pretty much the same for the Cabriolet except for the wiring in the hinge. My light was replaced by the dealer under warranty several years ago and the lamp itself looks ok. Is there a simple way to test the connections or the lamp before I order a replacement?
2007 CLK550 Cabriolet and 2014 GLK350
My outage was shown on the dash warning message. Other than a loose wire not sure how to test. A new one from RockAuto is around $100 and it's pretty easy to install. Make sure you keep a hand on the 2 nuts when loosening and tightening back on to the fixture.
Oh yes, DON'T SLAP THE TRUNK LID.
2004 CLK 240 Coupe
Discussion Starter · #78 ·
The new light assembly must be presented from the outside. The bracket should then be replaced, and when the nuts are tightened the bracket will hold the light assembly in place.. If your new light is passing right through the hole, you have the wrong part.
Assembly here is simply the reverse of dis-assembly.
2004 CLK 240 Coupe
Discussion Starter · #80 ·
As I remember it - yes. Not too tight with the nuts. Enough to keep the water out.
I think that I said it was easier to fix the connector on while the light is still outside. Have you forgotten how you took it apart?
