It is clear from the number of posts here on this topic that this item gives many of us a problem. Even if you have not already experienced a cracked third brake light (officially termed ‘center high-mounted stop lamp’) on your W209 CLK, the chances are that sooner or later you will. The design of the unit seems unable to tolerate the successive shocks that its mounting on the trunk lid is bound to inflict.
Tip: don’t slam the lid.
Editor's note: Repeat, Don't Slam the Lid! Close it gently but firmly, applying pressure only as it latches. This prevents the cracked brake light in the first place!
It is not difficult to replace the unit should you have to, even for the most inexperienced novice. Here’s a bunch of photos that I took when I replaced my cracked brake light recently. If your M-B warranty has expired, this shows you how it is easy to changeout the brake light yourself.
Image 1
my cracked rear brakelight, held together with transparent tape.
Image 2 - Parts required.
new third brake light assembly (part numbers differ according to manufacturer)
Image 3.- tools required
1. 10mm open end spanner
2. Torx 20 screwdriver
3. Pliers
4. Regular screwdriver
Open the trunk lid. Unlock the warning triangle and remove it.
Remove the warning triangle bracket, which also anchors the inner cover. This is held by a ‘spreading clip’, and to remove this you must prise up/out the center pin using a small screwdriver, and then ease out the outer clip with the screwdriver and pliers. These can be re-used so put them to one side.
Slide the bracket to the left, and use a small screwdriver to lift the inner plastic clip to free the bracket. This reverse image shows the fixings and the clip to be released on the bracket. Image 4.
Remove the trunk lid cover. To do this the 10 spreading clips that retain the cover must first be removed as described above. Image 5.
(continued)
Image 1
3. Pliers
(continued)
