The E430 is just a bundle of joy. Fun Fun all around! After getting the gearbox replaced, and while replacing the rear brakes because of the rust, I found the rear left wheel bearing to be lacking.
as usual, I tried DIY. I bought new tools (yay, always nice..) for the job.
If you really want to do your rear wheel bearings, you will NEED a press. Using a large slide hammer will not do the trick. I tried, and failed. The bearing wouldn´t even budge.
Even with removing the wheel carrier, and then using a 20t press, it was a 3 hour ordeal. This is one job where the DIY person should reconsider.
Picture of tool I tried. This probably won't work. The WIS Instructions have a complicated looking hydraulic tool for the job.
