1 - 8 of 8 Posts
2002 ML55
Last week my drivers side windows stopped working, due to this I took a part my center console to do the window switch fix.
Could I have possible interupted something that makes the NAV antenna function? It worked 10 days prior to me taking the center console a part (I hadn't used it in a few days).
To be more specific the NAV unit functions fine it just can't see any satellites, so I'm thinking somehow I disconnected the antenna from the unit.
Any thoughts would be appreciated.
1998 ML320
Did you remove the entire center console? If you did, theres a chance you disturbed the CAN BUS adapter or the VSS link to the MCS. I don't know how you would have hit the antenna, as the splitter for it is behind the dash (or under the seat, depending on the year).
Grab one of the DIY posts on how to install NAV in your car that is year-specific, and go thru the steps to install, reseat all your connections, and pray.
Ian
1999 ML320 (Sold)
I would reset the unit by disconnecting the battery and let it do a reset. I had the same problem and I reset the unit and then the I received the satellites.
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
pize98 - 4/20/2005 11:33 AM
Or pull and reinsert fuse #21 to reset. Works for me. [;)]
2001 ML 55AMG
If you send me your email address I can sen you a detailed copy of the NAV retrofit so you can check all your connections.
MBs
candrews - 4/20/2005 5:49 AM
Maybe your antenna ripped off? I remember a similar report a while back, and then he found, well, something was missing in the rear... [:)]
W203 modified
azinn - 4/21/2005 1:42 AM
Or got to FM station
PRESS MUTE + 1 + 3
There you will find a number of menus where one of them is called RESET
miroj - 4/21/2005 3:46 AM
PRESS MUTE + 1 + 3
No MUTE on my MCS. [:(]
1 - 8 of 8 Posts
