Oh Elders of the Forum, I come before you with sickened member of my tribe…
Okay, while replacing my OVP today I noticed some "weeping" or leaking around the seal of the thermostat on my aging 1989 300TE (please see picture).
1) Did I ID the bits and issue correctly?
2) I'm going to order a new thermostat (Behr) and O-ring (why do they not come together?)
3) Could this just be the O-ring?
4) Could it be something other than a failing thermostat and O-ring?
5) Other symptom(s): Very recently heater and defroster have failed to deliver any heat though fans blowing strong. Also noticed strong coolant smell intermittently. Looked but could not find this (or any) leak until today.
6) I've read several R&R thermostat threads and the procedure looks pretty darn easy (famous last words). I do have the 10mm at the top for bleeding. My understanding is crack that while letting it get hot with the heater on. Correct? When to stop?
7) Top off (if needed) through???
8) Anything (sealant-goop-wise) on the O-ring?
9) Many thanks in advance.
