521 - 533 of 533 Posts
Discussion Starter #522
Yup... and the reason is because some engineer designed a $10,000 toilet seat.
I have nothing to do with the design of an aircraft toilet seat. But I did test them. That probably accounted for $5000 of it.
Were you testing them from a pooper or poopee perspective? ie sending or receiving.
I'm not trying to be stupid John but what is a crash load? Just interested how the testing works.
There is a reason an aircraft toilet seat cost $10,000.
Never mind the exaggeration. :)
But you know those ashtrays in the lav doors? Little fold out stainless ashtrays?
$185.00 each.
Mostly testing and approving.
All aircraft parts...especially in the interior are tested for G forces, burn rate and toxicity.
It could be an off the shelf part from Home Depot....but until it's tested and approved and has documentation to back it....
Discussion Starter #528
Everything bolted down into an aircraft has to demonstrate it will not break off its mounts under acceleration forces that would occur in a survivable accident. The test is performed by pulling on the object in 3 direction at G loads specified by the FAA.
Discussion Starter #529
$185.00 each.
Yes and the ones in the Honda Jet are probably the ones used in an Acura. The Coffey pot in a Honda Jet was something like $18,000.
Discussion Starter #530
So AC system is now complete. With the exception that it really sucks. Still haven't figured out why I suddenly lost performance. I'm now thinking maybe my mono valve is leaking. I hate to replace that part because the only ones available are aftermarket MTC. I and many others have had significant problems with those. TBC
Discussion Starter #531
My grommet for the WW tank arrived with some 1.5" Al tube. I made a quick mock out of a 90° tube that I will be playing with mounting and plumbing solutions for the next week.
Don't worry about the welding.
When I have it all mocked up I will send it to a real welder.
1987 560SL, 2000 Kawasaki W650
Interesting. That’s probably why sometimes when I’m looking for electronics parts I will run across something like a potentiometer that for my needs is a $2 part whereas the top prices for components that perform the same function can be in the thousands.
E.g.: https://www.mouser.com/ProductDetail/Vishay-Spectrol/302C1102B01?qs=sGAEpiMZZMtC25l1F4XBU2wijbK1SzrXYmjMvhXO%2B4g=
Discussion Starter #533
Not a whole hell of a lot happening. I cant seem to get my head into working on the windshield washer until I get my AC sorted. I just got everything ready. I borrowed a recovery machine from my brother, got new filter for it, purged it out with nitrogen, changed my vacuum pump oil. All ready to go, then I found the recovery tank I got on E-bay had no DOT certifications or pressure test dates. So I sent that one back and now I have a genuine Robinair unit on order. I'm not fooling around. I also got a 30# cylinder of R134a. To get set up in auto AC today is very expensive. I'm getting pretty close. I really need to purchase my own recovery unit. That one I borrowed cost $100. to ship both ways. But next week I will have great charging weather, Mid to high 80's
So sooner or later I will purchase a recovery unit, but then new cars use a different Freon R1234, which requires a different recovery unit and tank.
