1 - 8 of 8 Posts
Today I went at Autozone (who owns Alldata) and I found out that for my 1994 C220 Dexron III was required. So I would advise you to stop spending millions for the Mercedes benz ATF which will do the same thing as a Dexron III fluid.
It also said that I needed 7.3 quarts. So I bought 8 and I spent 28 dollars.
Plus 19.90 for the filter kit at discount auto parts. Autozone was 35.
THis one is going to be a cheap transmission fluid change. Less than $50.
Just my 0.2
Dario
1986 190e 2.3-16 (W201), 1997 SL320 Panoramic Glass Top (R129) & 2009 C300 Panoramic Top (W204)
Keep them honest!
:thumbsup: Its true, I had my transmission fully rebuilt with all new Mercedes parts, the shop used regular Dextron III. No issues, just another way to over charge for a regular non-dealar item.:mad:
Dario,
Just so that there is no misunderstanding, it is only the 5 speed 722-6 tranny that requires the synthetic Benz fluid.- Dexron III will kill the 5 speed over time.
Your tranny would be a 4 speed - totally different animal!!
Oberoi
I think the point is: if the ATF meets the MB specs for your transmission you can use it. I would still be cautious before using anything after-market just because AutoZone says it is okay. At least in my area, AZ does not see enough Mercedes to be considered experts.
2004 Lexus LS 430 Modern Luxury. 2012 Acura TSX (fun fun) Maybe MB again one day...
Just my 0.2
Dario
722.4, NOT 722.6!
2002 ML320
I don't mind paying the extra... at least I know it is EXACTLY what is meant for my car... I mean, I drive a Mercedes... I'm not about to cut corners to save a buck... I still use the premium fuel that it calls for no matter how much it costs... thats the choice I made in buying Mercedes.
W202 BRABUS
Verrry true 722.6 uses MB Fluid. Itll cost you an arm and a leg for 1L at 16.00! But its what it needs. I still use 91octane as well.
2001 E320; 2002 ML500
maxell666,
You need to do your research first. Dexron III is OK for your 4 speed tranny but not for the later 5 speed trannies (which need the MB expensive fluid).
Sergio
1 - 8 of 8 Posts
