2003 CL600 Biturbo, CL2 Sport Package, Eurocharged / 2014 Jeep SRT / 2009 Saab 9-7x Aero 6.0
Hello All,
I hope everyone is enjoying a great day. I have seen this subject discussed in threads on this forum in the past, “The true horsepower of the 2003 CL600”. The engine used in this car was M275 from the Debut 2003 Maybach 57, and most specs are identical.
Engine Cylinders: 12
Engine Position: Front
Displacement: 5.5L
Valve-train: 3 valves / cylinder, SOHC
Compression Ratio: 9.0:1
Engine Bore: 82mm
Engine Stroke: 87mm
Fuel Feed: Fuel Injection
Aspiration: Bi-Turbo
Here are where the specs are different, on paper:
2003 CL600 - 493 bhp / 367 KW @ 5000rpm
800 Nm / 590 ft lbs @ 1800 rpm
2003 Maybach 57 - 543 bhp / 404 KW @ 5250rpm
900 Nm / 664 ft lbs @ 2300rpm
I own a 2003 CL600 that has the Eurocharged ECU flash done by John at Broadway Performance. This car is not 500 bhp! It’s lightning fast and dead quiet. No sound at idle or at 170 mph. I just purchased a 2014 Jeep SRT, specs state 4.5 seconds 0-60. I have done a 0-60 run using the launch control setting and ran 4.46 seconds. The CL makes the SRT feel like it’s standing still. So here is my question:
Is the true horsepower and torque of the W215 CL600, (at least the 2003 year) the same as the 2003 Maybach 57 @ 543 bhp, and 664 ft lbs torque, and what are those numbers and top speed after the Eurocharged flash?
Best regards to all,
Anthony
Displacement: 5.5L
Engine Bore: 82mm
Engine Stroke: 87mm
Anthony
