1 - 19 of 19 Posts
-----PLEASE DO NOT POST QUESTIONS OR COMMENTS ON THIS THREAD-----
If you have a suggestion or comment please post in the Tool Loan Program Comment Thread
This thread is a library of available tools made available by members of this 107 forum.
They are for loan or sale.
**All arrangements for borrowing, selling, shipping or payment will be made through PMs or email and NOT on this thread.
**If you have a tool you would be willing to offer for loan or sale, please post a picture, part number and a brief description followed by your personal loaning rules and ZIP code / postal code for shipping estimates.
**If a tool is already posted, feel free to post it again....multiple locations could lower shipping costs.
**If you want to borrow a tool and need additional information please PM or EMAIL the member who has posted the available tool.
**This program will only work if everyone respects the rules and returns the tool in good shape and in a timely fashion.
** Owner beware as the responsibility for deals gone bad will be between you and the loanee alone.
Thank you for helping make this a success.
NOTE: For tools not found on this registry please look here: http://www.samstagsales.com/mercedes.htm
Discussion Starter #2
CLUSTER REMOVAL TOOL
Part Number 140 589 02 33 00
Qty. 2
Will ship anywhere from CANADA- L4N-8W6
You pay shipping costs both ways.
PM me if interested.
VALVE ADJUSTMENT WRENCH
Part Number 110 589 01 01 00
Will ship anywhere from CANADA - L4N-8W6
FUEL INJECTION PRESSURE TESTER CIS K_JET
For K- JET injection systems.
I Have for loan
M117 Timing Chain Loader
M116/M117 Chain Rail Pin Puller
M110 Valve adjustment wrench
M130/M116/M117 Valve adjustment crowfoot wrench
Older Diesel (I forgot the engine) valve adjustment wrenches
M102/103 fan Clutch Tools
Mercedes Differential Carrier Support Tool
Eastwood Fender Rolling Tool
KD Universal OHC Valve Spring Compressor (Works on all SOHC Benz engines)
OTC Hub and Axel Puller
Harbor Freight Ball Joint Tool (Probably more expensive to ship both ways than the tool cost, but it does work)
Pay deposit and shipping
PM me if interested
Thanks to a generous member here, I have for loan:
P703
MB, VW, Audi, Master kit
aka Lambda/current tester
Same as before... shipping both ways inside US
Paypal deposit and shipping both ways for UK.
Head bolt removal tools.
Chain rail pin puller.
Spark plug thread chaser.
Head spring compressor.
Hub puller.
Engine crane and engine balancer (local pick up only).
Gonogo gauge. (prize if you can guess where the picture was taken from).
Prop shaft spanner (ignore the transmission vacuum switch)
560SL Throttle linkage needle bearing pilot arbor tool
Paypal deposit and shipping both ways for Finland.
560SL Throttle linkage needle bearing pilot arbor tool - necessary to remove old throttle linkage HK0810 needle bearings and install the new bearings.
I have the 4 pin socket for the differential yoke nut (use this when changing the seal). This was $70 shipped. Dont want to see anyone else have to buy one for a one time use.
I also have the 30MM socket for the tranny output yoke.
Forum Administrator , RC Colas® & Moon Pies®
I did the brakes last week on the 210 wagon and I wanted to post a pic of my newest tool. It's a wheel bolt organizer. I usually just scatter the bolts somewhere almost out of the way and end up kneeling on one or kicking one off into the grass somewhere.
If you're doing the whole car at once, you'd need two of these units.
If anyone needs a couple of these, you can shoot me a pm but you'd get them much quicker by running down to your local Home Depot.
Discussion Starter #15
Some fabricated tools to assist with maintenance on the automatic transmission. Available for loan on a shipping both ways basis. Unfortunately shipping will have to be confined to Australia. Importing timber back into Australia from overseas is a nightmare.
The operation of these jigs are described in my post:
https://www.benzworld.org/forums/r-c107-sl-slc-class/2958890-w107-transmission-removal-dummies.html
First, a cradle to get the transmission out then back in again. This will require a trolley jack and probably some holes drilled in the trolley jack to allow the cradle to be bolted on.
A modified deep socket is used to remove the rear nut on the transmission
A drift to safely insert the rear seal in the transmission
And a drift to insert the rear main seal onto the crankshaft
I now have these from rgrady and will be taking care of these for the tool loan program.
MB Tool Number 126 589 02 09 00 and Sir Tools M0026
1 - 19 of 19 Posts
