1 - 10 of 10 Posts
R/C107 Moderator
Very strange. Measure your old upper guides. If the are 172MM they may be the same as the 117 engine. #117 052 09 06.
1979 450SL UK spec
I'll check them out, but I seem to remember them being different.
Got a quote for new undersized camshaft bearings (0.25mm), £180 but will need to see if the old cam shaft is big enough, it may have worn too much.
A new camshaft and standard bearings will be the best part of £900, ouch.
Here is the epc showing only one slide rail part number.
R/C107 Moderator
Yes, I saw that. I wonder why it doesn't show the upper guides. The M117 shows them.
82 380SL 96 SL500 03 SL500
My info shows 3 of 1160521716. Of course it isn't the best reference.
R/C107 Moderator
I give up. The EPC doesn't even show them for the M116 in the 380SL.
Ah Ha. Re checked the 380 and it says 3 of the same as Alan listed.
RD. Did you toss the old ones?
1984 380SL, 1973 450SLC
All three on the 84 380SL were the same...
I believe they were original, about 77K, and 24 years old.....:eek: This was the chain, had about 8 degrees off on right cam.
1 - 10 of 10 Posts
