i have a ? for you i have a 98 with the 4 cam 4 valve motor. do you know anyone who can help get more hp out of it. i am thinking about putting twin turbos on it but then i have to change ecu .any off the wall ideas will help thanks
Port & polish throttle body to 82mm ($250), bigger air box, modified valve body for quicker shifts ($750), Bergwerks nitrous (1500$?), resonator delete (-30lbs), secondary cat delete (-15lbs), performance tires that are nitrogen filled, lightweight wheels, remove tire from trunk (-40lbs), replace seats with something extremely light (-215lbs). Could go hardcore and remove entire softtop & assembly (-200lbs+?).
If I were you I would just get a throttle body port/polish & change air filter to complement it & maybe resonator/2ndary cat delete for a definite acceleration boost.
Weight reduction is up to you. 🤠 My m119 SL is very high mileage with dents and stuff so I've replaced seats and took out softtop, removed cats, muffler, resonator, tire, etc..
It's more of an experimental toy. I'll be doing the port/polish soon & hopefully the valve body. If it is daily drivable after all that I'll do the same to a 2001.
I am currently saving up for a low mileage 2001 Sl500, which I will swap to a 5.5, shift kit, custom throttle body and I will keep it as a garage queen.
Maxbore.com
High Performance NAG1 722.6 Valve Body. Chrysler,Dodge, JEEP, Mercedes-Benz
southernhotrod.com
