1 - 20 of 37 Posts
SLK350
Read a lot threads about rattles and knocks but my week old car has this one - intermittent and only when going round bends or roundabouts (i.e. when the car rolls) a single loud knock or clonk that sounds like it is coming from behind - or even inside ! - the drivers seat (that on the right in the UK). Already driving me nuts - especially as I get it twice most times, once when turing left or right into a bend and twice when I straighten up. Anyone else experienced this and had it fixed ??
I owned an ML320 that rattled like a tractor fron new and every time I took it to the dealership they took it apart again and when I got it back there were bits hanging off it - and the rattle was still there. So I am obviously reluctant to take this problem to the dealer...
06 SLK 55 Firemist
Do you have Air Scarf? If so it may have come loose. The blower is clipped into place and looks like it could be easily dislodged.
SLK350
Yep got Airscarf and just checked it - all solid. THe sound is a lot louder and metallicy.
SLK 55 born 03/05
Mine was in for a check up and I was told my rattle was due to a loose "heat shield" that was tightened up. Will let you know if that was the problem!
SLK 350
I have some sort of noise also, I found it was that leather flap on the door, almost evertime I hit a bump I hear it. I'll have to figure out how to stop it.
SLK350
Guys - I am still suffering ! Took it to the local dealer the other day and the technician heard the knock straightaway - again only rolling into bends/roundabouts and then again rolling out - somewhere right side rear - I am sure it is the drivers seat.... He could not say for sure (of course) where it was coming from and needed to interrogate the corporate database to see if anyone had reported and had fixed a similar problem (interesting they have this database - obviously they get lots of problems....?). Anyway I am waiting to hear back but the dilemma is they will want it in to strip it down and they did this to my box of nails ML and it was never the same... Meanwhile the knock is driving me CRAAAAAAAAAAAZZYY ! Anyone ?
SLK350 6MT
someone on the assembly line probably left a tool inside that is rolling around. look on the bright side, maybe you got an extra that we did not.
i was driven crazy by a knocking sound for about a week and then i realized that it was the flashlight i put in the center console rolling back and forth.
SLK350
innherb - 5/13/2005 3:44 PM
The "manufacturers" of the software I work on have issues databases that they refer to regularly, in fact one internal one and one for users not hugely different from this R171 forum. Its good practice and I would not see it as indicative of lots of problems per se.
I had a bit of knocking at one point. I keep CD/DVDs in the drop down storage in the centre console. Since I only had a couple in there they moved around, but now I make sure there are enough so that they are secure in there, so no knocking.
SLK350
Discussion Starter #13
Should have said i have tried it with zero loading of anything anywhere in the car - even stripped the skinny inflatable and the polystyrene tool tray from the boot (trunk) and the knock still happens - oh and with roof up or down. Help !
SLK350
Discussion Starter #14
So - my car is booked into the service centre 6th June to investigate this knocking but I was cra**ing myself as experience with my M class and CLK is they strip the car apart to find the problem and NEVER put it back the same way again.
Anyway I had today off to enjoy the roof down with global warming 88 degrees in May in the UK and decide to visit the service centre. I told the senior technician I am sure the noise is coming from the drivers seat and after a road test he agrees with me ! He reckons it may be a 'stress fracure' of the seat !!!
At least the problem is pinned down and the solution maybe as simple as a new seat. Anyone else had problems with their seats ??
MBs, BMWs & Hondas
The fixes for this knocking sound seems to be 'everywhere'.
My SLK350 has been to the dealership 5 times and after they lubed the door strikers, lubed and retorqued the rear sway bar links, the knocking sound seem to have subsided.
My latest round has to deal with the wind noise coming from the left side (driver side) c-pillar window. I have the cracking sound (sounds like static from speaker but it is not) coming from the window area. So far, the dealership has realigned the window, replaced the seal, swapped out the window regulator .... sound has gone down but if there is a strong cross wind, you hear it again.
I hope this bit of info helps others with the knocking sound problem.
GL
SLK350
Discussion Starter #16
Well the car went into the service centre today and they located the problem with the drivers seat, apparently some bushes need replacing that connect the seat to the elctronic drive mechanism. This must be a lemon build issue rather than wear and tear after 1500 miles (I am not that heavy !).
Will report again when I get the car back tomorrow to confirm its fixed the problem. Meanwhile if you are having similar problems (see the original post on this thread) you may want to point them at this fix.
SLK350
Discussion Starter #17
Well they did not fix the problem - why am I surprised ? - because they thought they could order up these replacement bushes but MB are saying they have got to get some modified ones manufactured to fix this 'known problem'!! THe service centre cannot give me a lead time for deilvery so I just get the car back with the knocking...
I am sceptical this is the problem anyway - why ? Firstly it does not sound like its coming from the botom of the chair (the bushes are at the fixing point of the seat to the running mechanism) it sounds like its coming from the seat back. Secondly if the seat was not securely fixed surely I would feel movement - I dont. Thirdly the passenger seat does not make a noise. Fourthly, why hasn't anyone else on this forum reported this 'known problem' ?
I guess I have to give them the chance to get and fix these new bushes to see if I am wrong. Meanwhile it is spoiling my enjoyment of the car.[V]
Mercedes SL350 2009
I have a similar single clonk or knocking noise coming from the rear of the car somewhere when i go over bumps or sharply round bends. I am yet to rowk out what is causing it though
SLK350
Discussion Starter #19
Sounds like you may have the same problem as me. I spoke with the actual technician who diagnosed my problem and I am more confident they have correctly identified it. The bushes that need replacing are at the fixing point of the seat back to the seat base - not the base to the running mechanism as the front desk guy had told me (idiot !). He told me MB are replacing all these bushes on latest builds with a modified type - but only on the drivers seat curiously - and that is why they are out of stock.
Suggest you test this by going round a corner or roundabout fairly sharply whilst leaning forward (i.e. no contact with the seat back) and if you dont get the knock then you have the same problem - as it only happens when the seat back is under load. Then get your dealer/service centre to order you some bushes as well!
Good luck. [8)]
1 - 20 of 37 Posts
