With great anticipation the newly rebuilt 380SL engine ('82) found it's own moment to start, adding a hint of drama (leading to the: 'is it going to start?' question)...and then vroom-vroom, it began purring like a kitten from the very start.
Fast forward to the test drive: "shucks"...and other more colorful expletives...as bluish-grey smoke began to pour from the exhaust when the gas pedal was pressed...and the pedal seemed unable or unwilling to coax any power out of the newbie. Embarrassed by the lack of power and the billowing smoke on it's maiden voyage, the wundercar turned tail and went home. I have a long uphill driveway and the pedal was floored all the way up as we barely made it.
The analysis: (in retrospect)
1. No high idle to start...idled smoothly and smoke free at 500-600. Would not have taken it on the test drive had I noticed any smoking during the warm-up.
2. Gas pedal seemed like it had difficulty moving past idle speed...finally, during the warm-up phase the revs were increased successfully to 2500...but it seemed like it needed babying to do it. Not linkage...engine responsiveness seemed in question.
3. Compression check today..all 8 cylinders 150-160.
4. Heads professionally rebuilt...I won't exclude valve seals , but I suspect they are not the immediate issue.
Searching the forum has lead me to the warm up compensator as possibly supplying too much fuel (pressure) after warm-up which would lead to the "richness".
I disassembled the compensator( regulator) and found it unrevealing. All seemed perfectly well. Except there is an adjustable 'piston' of sorts that moves up and down as the diaphram moves in relation to engine vacuum. I noticed the adjustability of this item seems infinite and would appear to have a major impact on the workings of the compensator. But I do not find any literature or commentary about "tuning" the warm-up compensator. For example, I would expect that somewhere there are instructions to make the initial setting thus and so.
Any expertise on this? Thanks
