1 - 8 of 8 Posts
1985 500sel
MY ECONOMY GAUGE WAS ACTING CRAZY SOMETIMES WEN I STARTED THE CAR IT WOULD STAY IN THE MIDDLE INSTEAD OF ALL THE WAY BACK. THE CAR WOULD ALSO SHAKE A LITTLE. DOES ANYONE KNOW WHAT WAS CAUSING THAT?[8][}:)]
1988 420 SEL
VACUUM OPERATED
PimpinBenzo - 3/3/2005 4:07 PM
IT'S VACUUM OPERATED, SO MAYBE YOU HAVE A VACUUM LEAK OR A LEAK IN THE INTAKE MANIFOLD.
420 SEL
You have a vacuum leak, mine did the same thing and I found the hose to the modulating valve on the g/box had come loose from a rubber fitting that had deteriorated. Check all your hoses and you will find it.
420 SEL
89 420 SEL (sold), 01ML320 (sold), 03 S430 4MATIC, 06 ML500
I think your plugs are fouled up and this is not creating enough engine vaccuum. Check the state of the plugs for oil burn first!
1984 500sel
regarding vacuum leaks. I'm pretty sure mine is shot. the economy gauge, door looks, ac stuck on low. Are there any other functions the vacuum system does? Is this just a matter of hoses or would motors and pumps be envolved. lastly is this an easy project that an average person could do?
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
On U.S. / LHD cars, vacuum hoses connect to a white plasic fitting at the front of the fuse box. Check if a hose has come off.
1 - 8 of 8 Posts
