Working on one’s own vehicle isn’t for everyone, and perhaps especially if that vehicle is a Mercedes-Benz. The brand has a reputation – not entirely undeserved – of producing overly complicated, over-engineered, difficult-to-work-on automobiles that are best left to a professional.
But the truth is, while there are some jobs you don’t want to touch with a ten-foot pole, there are plenty of Mercedes maintenance and repair tasks that are perfectly within reach for anyone with the will. Of course, getting started as a home Mercedes mechanic will require a range of tools. Where is a DIY-leaning Merc owner to start?
We’ve attempted to answer these questions for you here. What follows is a list of the best tools and gear every Mercedes owner needs.
1. FOXWELL NT510 Elite OBD2 Scanner
Telephony Communication Device Gesture Gadget Font
If something is worn out or faulty on your Mercedes, chances are your car already has a good idea of what the issue is. An OBDII scanner plugs into a specialized data port on your vehicle, and then reads and interprets any extant fault codes. The thing is, while OBDII is an established protocol, automakers use a lot of proprietary codes that can’t be readily interpreted by just any scanner. One solution? This FOXWELL NT510 Elite OBDII scanner. It’s aimed specifically at Mercedes-Benz, Sprinter, and Smart vehicles, so chances are good that it will be able to interpret whatever your Merc is trying to tell you. You can use it to read and clear codes related to the engine, transmission, brakes, HVAC – all sorts of vehicle systems.
CHECK PRICE
2. Jump-N-Carry JNC660 Portable Jump Starter
Camera Camera accessory Cameras & optics Font Digital camera
No one heads out into the world planning on having a battery failure, but when it does inevitably happen to you, it’s nice to be able to take care of it quickly yourself. That’s when a lithium-ion portable jump starter like the Jump-N-Carry JNC660 comes in handy. This option is a bit pricey, and it doesn’t come with many of the bells and whistles found on some portable jump starters – things like a flashlight, a built-in air compressor, etc. But it’s well worth it because it’s hands down one of the most powerful, reliable portable jumpers on the market. It puts out up to 1,700 amps of current, which – if we had to guess – is probably enough to jumpstart a freighter. Okay, maybe not, but it’s certainly more than enough for any passenger vehicle, and it gives you a bit of extra certainty on frigid winter days.
CHECK PRICE
3. Craftsman 450-Piece Mechanics Tool Set
Tire Wheel Automotive tire Vehicle Automotive lighting
A good socket set is everything to a mechanic, and Craftsman has a sterling reputation for quality in the home mechanic sphere. That’s a big part of why we recommend this 450-piece mechanics tool set. Loaded with a vast array of tools in both metric and SAE sizes, this tool set covers all the bases, with a staggering 191 sockets, 175 bits, 16 wrenches, and a number of other common-use tools that you’ll need to perform maintenance or repair work on your Mercedes vehicle. That includes a number of deep-well sockets for those rare occasions when you actually need one. No matter what you’re doing, this tool kit covers the vast majority of tasks you’ll ever need to perform. Oh, and did we mention the limited lifetime warranty?
CHECK PRICE
4. Tekton 3/8-Inch Click Torque Wrenc
Line Tool Cleanliness Rectangle Office supplies
Worried about under- or over-tightening a fastener on your Merc? You should be. Auto manufacturers come up with torque specs for a huge number of the nuts and bolts in your vehicle, based on what sort of clamping force is required for the component in question. A click torque wrench like this Tekton 3/8”-drive one contains an internal mechanism that makes an audible “click” when you reach the set torque threshold as you’re tightening down a fastener. This Tekton wrench has a torque range of 10 to 80 lb-ft and a 3/8” drive, making it ideal for the vast majority of automotive applications.
CHECK PRICE
5. ABN 2-Pound Dead-Blow Mallet
Automotive lighting Font Nozzle Auto part Logo
It might give you heartburn just thinking about smacking any part of your Mercedes with a dead-blow mallet, but it’s nonetheless an essential tool for so many repair jobs. Dead blow mallets are typically filled with small metal beads that help absorb tremors any time you strike something, minimizing rebound and helping prevent marring damage to softer metals. This 2-pound ABN dead-blow mallet is just right for automotive use, with a soft rubber coating to help prevent damage, and sufficient heft to help unstick frozen parts and fasteners.
CHECK PRICE
6. COB LED Work Light
Rectangle Gesture Font Automotive lighting Electronic device
Believe it or not, but the ideal work light solution is not an eight-year-old with a flashlight; it’s something like this COB LED work light. Small, inexpensive, lightweight, and magnetic, these LED work lights can be purchased two, three, or four at a time and stuck onto just about anything made of ferrous material – including parts of your Mercedes – to provide you with ample illumination while you’re wrenching. Each one has a rechargeable lithium-ion battery contained inside that can provide up to 5 hours of illumination on a full charge, and they’re water-resistant, so you don’t have to worry about them shorting in the event they get a bit wet.
CHECK PRICE
7. JEGS 3-Ton Professional Low-Profile Aluminum Floor Jack
Automotive lighting Automotive tire Motor vehicle Vehicle Automotive exterior
Raising your Mercedes to change the oil, rotate the tires, or perform other maintenance or repair work can be an intimidating task, especially if all you’ve got to rely on is the basic scissor jack that came with your car. We might recommend this JEGS 3-ton floor jack as an alternative. It’s a bit on the expensive side, but well worth the money if you want a high-quality, practical floor jack that will last for years and years. The aluminum alloy construction means it’s significantly easier to move and position than a comparable steel unit, and the low-profile design ensures that the jack can slide up underneath just about any Merc with no issues. It’s basically like the Mercedes-Benz of floor jacks.
CHECK PRICE
8. Esco Low-Profile Performance Jack Stand
Bicycle part Camera accessory Tool Machine Electric blue
A premium vehicle deserves to be suspended by a premium jack stand – something with a rubber-covered flat top that won’t dig into or mar soft aluminum suspension components, or leave nasty pinch points in your frame rails. This 3-ton Esco jack stand is our top recommendation. Keep in mind: these jack stands are typically sold per each, not as a pair, so you’ll have to enter a quantity of two to get two stands – the typical minimum number required for jobs like tire rotations and oil changes. Regardless, these jack stands feature a time-tested pin-type height retainer, and they’re better built than just about anything else on the market. Take it from us: jack stands are not an area where you ever want to cheap out. Your life could literally depend on them.
CHECK PRICE
9. Fluke 101 Basic Digital Multimeter
Measuring instrument Font Gadget Technology Electronic device
A multimeter is an absolutely essential bit of equipment for helping you diagnose and track down electrical faults in your Mercedes-Benz, and the Fluke 101 digital multimeter is our pick for basic auto repair duty. It has AC and DC voltage modes, a resistance detection mode, and even modes to detect capacitance and frequency, all from a very well-regarded, trustworthy brand known for their precise, reliable testing equipment. You should never have to guess-and-check your way to a working electrical system, and with the Fluke 101, you won’t have to.
CHECK PRICE
10. Ryobi 18V ONE+ 3-Speed Cordless Impact Wrench
Handheld power drill Impact driver Machine Hammer drill Measuring instrument
We hate to admit it, but there are certain jobs that just can’t be done without an impact wrench. Back in the day, your only options were pneumatically actuated, but the advent of lithium-ion battery technology has given birth to a new generation of cordless electric impact wrenches. Hence, the Ryobi 18V ONE+ 3-speed impact wrench. It’s got plenty enough grunt for 99% of situations, supplying up to 300 lb-ft of torque and as many as 3,200 impacts per minute to help you drive fasteners on tight, or loosen stuck ones, without the need for an air compressor.
CHECK PRICE
11. Oil-Dri Premium Loose Absorbent
Spilling oil is a major bummer, not to mention an environmental hazard. That’s why pro mechanics always keep a certain amount of oil-absorbent material on hand to quickly spread over a spill and soak it up. Oil-Dri Premium Absorbent is our choice for this task. It’s made from processed Montmorillonite Clay, which takes up oil like a sponge and then sweeps away with ease. Just how absorbent is it? This 32-quart bag is enough to take up as much as 3.2 gallons of oil. Naturally, it won’t completely prevent staining – nothing can. But it can lessen the severity and make cleanup much simpler.
CHECK PRICE
We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
