1990 Mercedes 560SEL
Originally Posted by BigD560
Hey Teutone,
Would you mind sending me the following service files?
* 07.3-205 - Removal, reinstallation of fuel distributor
* 07.3-215 - Removal, reinstallation of injection valves
* 07.3-216 - Removal, reinstallation of insulating sleeve
* 07.3-220 - Renewing air flow sensor
* 07.3-230 - Removal, reinstallation of throttle assembly
* 07.3-251 - Removal, reinstallation of idle speed control unit
Thanks again,
Thomas
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
216 & 251 do not exist on my service CD's, the following pdf are listed:
# 07.3-199 - Survey mixture preparation
# 07.3-200 - Removal and installation of mixture control unit
# 07.3-205 - Renewing fuel distributor
# 07.3-210 - Reconditioning system pressure regulator and pressure compensating valve
# 07.3-215 - Removal and installation of injection valves
# 07.3-220 - Renewing air flow sensor
# 07.3-225 - Removal and installation of mixture control unit with air guide housing
# 07.3-230 - Removal and installation of throttle valve housing
# 07.3-242 - Retrofitting safety switch to air flow sensor
# 07.3-245 - Renewing, centering airflow sensor plate, checking and adjusting zero position of air flow sensor plate
# 07.3-269 - Survey fuel pump assembly
Thank you teutone, much appreciated!
