1 - 1 of 1 Posts
1988 300TE, 1995 Audi 90quattro Sport
Hi all - How do you test compression on a diesel? Do you go through the injectors or the glow plugs? Where can you obtain the correct gauge and fittings for doing the job? What is the procedure? Is it different than gasoline motors with regards to engine temperature and throttle position when testing? An MB 3.0 Turbo should be in the 3-320psi range, correct?
Thanks!
1 - 1 of 1 Posts
