G
Guest
·Well Lets see
when it reached redline did It go down? or no? Check your coolant warning on your car. It is sometimes an occurance when the outside temp is high like here in N.cali where it was 102 and your ac is running and you are in a stop and go situation.. If it happens again check with you dealer to find out if you are low on coolant or take it in so they can test the Thermostat sensor.. Let me know the conditions of that day and what kind of driving you did.. BTW how good is the AC on the clks'?<p>
