I've noticed the US version of the SL500 has a blank TV button. <br> <br> Is this an option or upgrade that will be offered later or once the car is at the dealership?<br> <br> -Chris
Ah. that explains it. Although putting drinks in those high up cupholders seems like a sure way of getting sticky drink in the COMAND or other expensive switch gear ...
You can add a video digital input to the command system. There is a problem with the tv tuner since weak signaks cause the screen to loose image.
You can add the tv tuner function, which is activated by the stardiagnosis computer at your dealer, which pretty much is illegal in the US.
There are many ways to go around this, all depend on your budget!
JB
There were only 2 for sale in the entire nation, searched from craig's list to cargurus to eBay...only 2 results, one happen to be 5 miles from me the other is in California 3000 miles away. Loving it so far, it's absurdly fast and drives like a dream, interior and exterior look like it came...
The fuse for the trunk soft close function is in a tight spot behind the passenger seat below the storage bin. Seems like I usually end up bleeding when pulling it out to reset my system. I can't seem to locate the air leak that makes this a weekly ritual. This is a real pain when I can't raise...
How much is a "standard" tune up for a 2003 SL500 AMG? Just a ball park so I can tell if I am being overcharged. Also, what type of battery is the best for this car? I have been told Interstate but it looks like some folks do not like Interstate. Any suggestions? Thanks.
The other day a buck ran right into the side of my SL500. Luckily the only damage was the plastic around the little stubby antenna - both base and cap. I bought a replacement and thought pull the interior trunk panel and easy fix - wrong. So the first question - is the best access to this...
This is a guide to the CAN bus in the 230 it applies to all models right up to 2008ish. This is not an explanation of how the CAN and WAKE UP work, it is a guide to a simple way to know if your car is going to sleep, and how you can check with just 2 voltage checks. We are only dealing with CAN...
