1992 SL300-24, 1998 BMW 750iL
Hello
I know im going to be put at the stake here but here it goes...
Im planing to convert my R129 to run a supercharger setup, as far as im aware...the 98-2000 SLK's came with an Eaton M62 while 2000+ came with an M45 supercharger which is common with the Mini S....My car is an M104 inline 6 3L engine
My question is...some of the superchargers fit on both 4 cylinder and 6 cylinder models from a 2.3L-3.2L displacement engines...if i ran with a supercharger from a 4 cylinder, would the efficiency decrease due a bigger displacement from what the supercharger was intended to work with?
82 380SL 96 SL500 03 SL500
Either would probably be fine, but the big issue will be the pully sizes to spin the supercharger at the appropriate rpm for your application. OTOH, what would I know.
I'd go over to the 170 and 171 forums for a perhaps more studied opinion.
already did...here is what i got
"Yes, you will have to spin the smaller supercharger higher to achieve the same hp increase compared to the larger supercharger. Alternatively, you can look for a used M90 from a Jaguar."
