101 - 105 of 105 Posts
1999 SLK230 Kompressor
R170 pre facelift wiper clonk noise
The clonk was mostly noticeable on intermittent and was only found when the scuttle was removed, wiper blades refitted and a careful study of the all the moving parts made.
The wiper motor has a circular black casing held on with two T20 Torx bolts to the alloy top section/gearbox. These were loose allowing the black casing to twist and clonk when the motor started.
Moderator
1998 SLK 230
Moderator
1998 SLK 230
How to remove boost cut on post-facelift cars (m45 supercharger)
This occurs when boosting over 12psi the system cuts out and you must re-start the car to function correctly again.
1) Remove front and rear engine top covers.
2) Locate the MAP sensor (intake manifold - under the throttle body, not the MAP sensor on the top of the manifold) with 3 wires going to the main harness.
3) Cut the wire that has brown stripe.
5) Solder inline 4000 ohms (4k) resistor and use shrink tubes to cover the open wire.
