2000 ML320E
I have a backup sensor display unit that I'ld like to attach to the dashboard, but I need a 12 volt power source.
I'll most likely place the display unit on the left or right side of the steering wheel (on the dashboard). I'd like the unit to have power only when the key is in the ignition (similar to the ashtray power source).
I was thinking of tapping into the ashtray power, but that would mean I'd have to remove most of the center console (with gear shifter) to access the power and hide the wiring.
Where's the easiest place get a power source? Suggestions please !
98ML320
Why don't you tap into the 12V power source in the passenger footwell. It is very easy to take that piece down and even easier to run the wire across the bottom of the dash.
