1 - 10 of 10 Posts
300 sl
hi all,
i have a 300sl 1989 which has done 103,000 k's.
if the car is left standing for a few days without starting, hen i do start it there is a slight tapping from the camshaft area.it only lasts for 2-3 seconds.used daily this does not occur.
does anyone have any ideas?
i live in zimbabwe and there are not many places to ask for advice.
thanks for your assistance,
paul
R/C107 Moderator
Welcome to the forum. Nice to have another country represented.
I don't think you have a major problem. I also do not know if the M103 has hydraulic compensators or solid like the M110. This is kind of a rare engine to be discussed here.
Maybe someone else will jump in with more knowledge.
87 560SL
In general, older vehicles with hydraulic lifters will sometimes bleed down when parked. Often this is not a serious problem if they pump up promptly.
It Is What It Is, Dude
hi all,
paul
Do a search for threads by contributor bereng. He has a 300SL and has done a lifter / compensator R&R. Not that I think that's an imperative. As jay-h says, if it's pumping up quickly you're probably ok, for now. Most important though is to listen for changes.
If it were mine I'd throw an oil change at it, with a quart of Lucas oil treatment. I liked it for both my M110 and M117. Don't know if that's an option for you.
'80 450SLC Afro RHD Ikonengold
I have tha same fault on my other car as the time for oil change nears.
~10000km and lifters will be noisy, new oil = no issues.
There may be a fault like described a bove but I just change oil more frequently
300 sl
thank you all for your very helpful replies,i will let you knowif i solve the problem,but it does not sound too serious.
paul
300sl 1987
Trillonaire indeed!! :-DDD
Anyway, you should have sent me an email. I don't usually read all threads and came across your's by chance.
I had the same problem and it made me uneasy though the car was running great, so I replaced all the hydraulic lifters:
w107 / liftersReplacement
Cheers
107, 115, 116, 123, 124, 126
I would say the important thing is to NOT rev the engine until the tapping goes away. Just the oil getting recirculated.
300 sl
you were right that we did used to be zillionaires (zim dollars!!) but unfortunately we are now us dollars, but it does make writing out a cheque easier without having to work out how many noughts to add!!
thank you all once again and i will let you know how i get on.
paul
1 - 10 of 10 Posts
