1984 mercedes benz 300d
ok so i already posted this question but now i have all of the symptoms... My 84 300d will intermittently take off, from a stop, in 2 gear and rev really high. sometimes, if i manually hit the the kick down switch behind the accelerator pedal it will drop down to first and take off as normal, other times it takes a few tries. today i bought a new kick down switch and i will be trying that tomorrow. Any other ideas what it could be?
2001 Volvo V40
First check the oil level.
If you don't know the last time the transmission oil and filter was changed, do that first.
Check the bowden cable on top of your valve cover, there should be no slack at the idle position.
Check the vacuum.
1980 280e
be carefull when you check the transmission fluid and make sure you wipe the stick with a lint free cloth or piece of leather (from the owners manual).
ok so i ajusted the bowden cable and it didn't change my first gear issues. how does one "check the vacuum"?
1983 300D Turbo , 1983 380SL , 1995 E320 , 1999 C43AMG, 2007 E350
I had similar symptoms and found my bowden cable had jumped the stop on the valve cover. You might check it out.
