1 - 8 of 8 Posts
i checked the lights today to make sure everything was working ok - the faulty bulb warning light in the instrument cluster is disabled due to the aftermarket hid headlights fitted. at the rear, moving from outside to center i see there is the indicator light (ok), a combined stop/sidelight bulb (ok), then a reversing light (also ok) and then a single bulb in the red housing which doesn't come on. i'm guessing its either another rear sidelight or a rear foglight. can anyone tell me what it is? :confused:
Hi according to my handbook for my 90 model that is the brake light,the combined bulb you speak about is tail lamp/parking lamp and fog lamp on the drivers side,if you are LHD the fog lamp will be on the other side hope this helps
Fog light. I will come one when you select fog lights on the headlight switch.
Sith Lord
Only one fog light in the rear. Like Roadking mentioned, it works when you pull your knob outwards.
1 - 8 of 8 Posts
