98 e320
OK boys. You know you want that 2001-forward look in the back. Just remember you better have a Dremel type grinding bit, and get ready to grind the crap out of inner (on the deck lid) lights on the side with the two mounting screws, because if not, the inner ones will NOT fit. If you have the patience, it's worth it. You can get the whole set for about $200 plus shipping from John at Wholesale Parts in Austin. 1.800.234.4441 ext. 5721. Here's how mine came out:
Before:
<img src="http://img2.uploadimages.net/417049e320_ss2_15jan04.jpg"/<p>
After:
<img src="http://img2.uploadimages.net/513297e320tail.jpg"/><p>And remember: Today's a perfect day to chase tornados!
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Not every day is good for chasing tornados like nice sunny days... Did you install Doppler Radar in your Benz?
Good job on you tail light upgrade. With a dremal tool, it goes pretty quick.
98 e320
One more thing to remember: The inner right connector IS NOT LONG ENOUGH. DON'T PULL ON IT. Simply cut it, patch about 3" of speaker wire to extend it, cover your splices with electrical tape, and voila, it's long enough.
