1 - 15 of 15 Posts
W123.223 - 230E - 1983
hello.
i installing tachometer for my w123.223 230E m102.980 or 981...
there not installed in factory...
mine is manual injection system.
i use hyndai sonata 2 rpm meter
my instruction is...
that one.
installed after. this red arrow... kk, it's normal working...
see signature
For a 230E you don't even need a tach amp, although you do need a four-cylinder version of the tachometer. That might be difficult to find.
Mercedes W 123 Drehzahlmesser bei eBay.de: Oldtimer-Teile (endet 03.11.10 17:17:03 MEZ)
Unfortunately, seller doesn't give shipping info outside D-land. You'd have to email seller for that. Now, what is REALLY hard to find, and expensive to buy once you do, is the 6cyl Drehzahlmesser (tach) with a CHROME needle button! I want one!
2001 Volvo V40
The chrome needle button was used up to and including the 2nd series, i.e. Sept. 1982. Six-cylinder models were less-produced, but more had options like the tachometer.
For some more pictures of tachometers, see here:
Drehzahlmesser im Vergleich
see signature
thanks, that is some great tach info!
Discussion Starter · #7 · (Edited)
i'll change this tacho because i found w124 tacho with clock. /installation modded/
like this. right one /max-7/
Discussion Starter · #8 ·
changed this tacho meter, from diesel 240d....
77 240D
i'm impressed you have access to old mercedes parts at all. is there a specialist wrecker in ulan bator or are you ordering things from russia or china?
Discussion Starter · #10 ·
all parts in Ulaanbaatar, some parts from china /hood star, molding, .../.
R.I.P. Never Forgotten
1983-2007 MB's
Do gassers (i.e. 230/280's) that have full size clocks come pre-wired for tachometer installations, or does one have to wire it in manually to the coil?
2001 Volvo V40
You have to wire it yourself if you install a tachometer. Usually the TD connection is used, not the coil.
'86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
1 - 15 of 15 Posts
