Tachometer pop up at my W124 300D when I turn the key and goes to 7000 rpm and turns back slowly to 2000 rpm and stay there - when I continue to turn the key to start engine and after engine starts the tachometer indicates corect the rpm during all the period when engine is functioning. After I stop the engine the tachometer goes normally back to zero. The pop up issue is only when I turn the key and goes out when engine starts.
Any ideea why this is happening this when normally the tachometer should stay at zero when the key turns and only to go up when the engine starts to function?
Thank you in advance for your replies!
