I am in the process of replacing all vacuum componenets to my 1972 450 sl as part of an entire ground-up restoration (lunacy--yes but...). There are three vacuum switch over valves: two on the back fire wall just under the blower cover and one mounted on the radiator reserve tank support. They look like little, round, metal hats. The new valves are completely different!
The two valves at the fire wall have have three openings top, bottom (center), and bottom (lateral).
The valve under the radiator tank (which leads to the distributor vacuum and throttle) has two ports on its underside (a central and lateral port) and none on the top.
The new valves are entirely different and are stamped positions 1)-bottom; position 2)-top; and position 3)-lateral. I understand how these electrically gated valves work.
However, can anyone please give me a precise idea exactly which ports of the OLD valves correspond to the three marked positions (1, 2, and 3) on the new valves? Finally, how do I use the third valve (under the radiator reserve) and what do I do with the third un-used port? My local mercedes folks are utterly unhelpful on this.
Finally, the two-barreled electrical connections do not have a guide pin to ensure polarity. My old set up had the label on the plug facing away from the center of the valve...do I merely continue this theme? How should I re-hook these plugs?
Thanks greatly!
ps: because of the "sticky", I have already replaced all lines, connections, and diaphrams...but this is not as obvious of a direct substitution!
Thanks greatly!
