At the suggestion of my very knowledgeable mechanic, I'm switching my '92 2.6 over from conventional 10W40 to SAE30 (straight weight) oil (brand is Shell, I assume most straight weight oils are pretty identical).
In addition, I'm adding 1.2 quarts of Lucas Heavy Duty Engine Oil Stabilizer for my next oil change (it's eating a quart of oil every 1000 miles - and there's no dripping leaks)
I do have one question: should I keep adding LubroMoly MOS2 Cold Start additive, or is that partially going to defeat the purpose of switching to a straight weight?
I'll be monitoring oil consumption after this, and I expect it to decrease significantly. I live in sunny Southern California, so cold temperatures will never be a real problem (dropping under 40F here is an extreme rarity), and the extreme heat stress LA traffic puts on this car makes me think this is probably the best way to go.
Has anyone else tried running straight weight in their 2.6? Good, bad experience? I'd love some tips or comments.
