Has anyone upgrade their suspension system use Calsson/Brabus or H&R cup kit ?? I found that the standard setting is a bit too soft always swing a lots around corners. <br>
<br>
Any recommendation ? So far Bilstein has not yet release the kit for C203. Both the Carlsson & Brabus use Sachs. The H&R lower 50mm front & 35mm rear. Carlsson lower 35mm front and rear.<br>
<br>
I would like to know which one gives better handling and which provides better ride.<br>
<br>
ps. I heard that if you only upgrade the springs the suspension will not last long ?<br>
<br>
<br>
Thanks<br>
DoDo//<br>
<br>
<p>apt-cse-538.cisco.com
