I can't wait for your update on the Steelman!
Probably for members that have been on the forums for a while (ie not lending to new or recent members I've never heard of)...Ps2cho, would you rent out your Steelman tool to a fellow member? I have been chasing a rattle in my W211 front for almost 2 years, changed everything twice and no luck.
All MB parts used! 4matic has a number of stuff that has no OEM anyway such as Lemfoerder etc...Are you using all Genuine MB parts or OEM?
Do I misunderstand you? I have 2 control arms per side, a leading and trailing conrol arms. Both attach to the subframe and the other ends attach to the steering knuckle via ball joints. This is on 2w rear drive.Your car must be a 4matic then? Standard 2WD lower control arms only have one attachment point to the frame!
I might end up needing to change my LCA bushings on the front end here too, the rubber is showing stress fractures just like yours, but they're not creating noise yet. My thrust arm bushings are a bit worse, I'm going to be changing those next weekend!
