In the UK, every car over 3 years old needs an annual comprehensive test at a certified MOT station. The tests check the vehicle for general road safety with figures to be met for brake efficiency and emissions. Visual checks are made of lighting, signalling, suspension, etc.
Last year my car failed its 2014 test when a broken front spring was discovered. I was unaware of this damage as the car sat and drove normally. The break was at the bottom end of the spring, the final 4 inches, where it sits in the cup. The broken ends were rusty, so it was not a recent break.
Last week my 2015 MOT test was done, and - would you believe it - another broken spring was found, this time at the rear. Again the ride is normal, the break is at the final 4 inches of the spring, and it is very rusty.
These are the only mechanical failures I've had on this 2004 CLK, so it is surprising that front and rear suspension springs seem to be a weakness on the car. I've never had a broken spring on any other car - over donkey's years!
