My WHITE 06 ML350 has been taking a beating with the winter weather this year. After a wet snowy trip through the iron mining areas last winter, a car wash revealed that many tiny flecks of metal from the road must have stuck to the finish and then rusted and discoloring the clear coat - many tiny rust colored spots on my white paint. I was able to remove them mostly. However this winter I am finding this to be an even larger issue without driving out of my area. It seems impossible to keep the car dry let alone do a wash because of the weather. Any idea on what really is causing this, how to avoid or prevent, and how best to remove the small spots once it warms up?
Its caused by industrial fall out.
What you can do is use a clay bar to get rid of the spots and then use a good sealant afterwards. I find that Collinite Insulator Wax works really well against the problem and last a long time, but thats just my opinion. Bottom line is you need some good protection on that paint.
Brake dust from metallic pads cause this too as well as rail dust from the transport train.
